Going to start the project on my old high school 66 Impala around June 5 when I get back to MT. Here's a couple pictures of what I have to deal with, and a picture of my truck. All the parts are here, some in worse shape than others, except for the motor. I'll be putting in a strong 406 Chevy small block with a TH 350 that is presently in my 66 Pickup here in AZ. I plan on a 3 summer project, but hope for it to be finished by September 2015, but I'm sure it will take much longer than I anticipate. But, the journey is half the fun, if not more, so I will enjoy it.
First priority is pulling the body of the frame. I'm sure the body mount bolts are thoroughly rusted, so they will probably have to be cut off. Once the body is off, I plan to have the frame sand-blasted and powder-coated once it is completely dis-assembled. IF the frame is any good, that is.
You see, I bought this car June 1, 1979 (for $150). It ran, but used more oil than gas, so I had the original 327 (long gone now) rebuilt. I drove it through high school in MT, then in college, first in Bozeman, MT, then Phoenix, AZ. In December 1981, on the drive back for Christmas vacation, the guy driving it at that time (I was the passenger) put it in the ditch at the Craters of the Moon in southern Idaho. He managed to hit the right rear tire off a GINORMOUS boulder, which bent the panhard bar connecting the frame and the rear axle 90 degrees. Yes, it was a perfect right angle. We had it repaired, but ever since then the left rear tire was an inch or 2 closer to the fender than the right rear tire. I believe the frame was bent in the collision with the boulder, but possibly only the trailing arms were pushed out of whack.
My question is how do I check for a bent frame once the body is off? I've had a couple guys look at it over the years, and they said the frame looks ok, but before I haul it to a frame shop I would like to find out for myself. I would prefer to use the original frame if possible, so I will have it repaired if necessary. Thanks, and I will keep this thread updated often with my progress.
