P0455 Code
1 reading
35K views 24 replies 8 participants last post by  RickCoMatic
#1 ·
Hello,
I have a 2013 Impala Flex fuel 3.6l. I recently had my check engine light come on with a P0496 code. I took it to a local mechanic, because my Chevrolet dealer took four hours just to do an oil change and I didn't feel like waiting on them to take forever just to make me pay them a lot of money. The mechanic told me to buy a new fuel cap and drive regularly for about a week to see if that fixed the issue. Well it didn't, so I took it back to him. He did a test on it and said it was my purge valve solenoid. I paid him $125 to fix that and the car did great for the next two weeks. When I tried remote starting the vehicle, it wouldn't start. I manually turned the vehicle on to find another code. I checked it with my OBD2 scanner and now it is showing a P0455. I am now lead to believe that it could be the canister solenoid. I was going to go about this by repairing it myself. However, the part is $70 and I don't want to replace it if I don't know that this will fix it. When I clear the code on my car (only done twice) it doesn't come back on until I try to remote start my vehicle. I'm not sure if anyone else has had this issue or not and if they have, I'd like to know how you went about fixing the issue.
-Thanks
#2 ·
Unfortunately, I don't think there is any way to be 100% sure if replacing the canister solenoid will fix it or not, but it sounds like you're on the right track. There are 2 different parts related to this system - and usually, it's a gamble as to which part it is. You've already had the other part replaced (the purge valve solenoid), so there is a pretty good chance that replacing the canister solenoid will fix the issue... I would do it. This seems to be quite a common issue on the 2012+ Impalas...
But, like I said, no guarantees...
Unless someone else has a better recommendation (I'm NOT a mechanic)!
Sent from my OBOOK 11 PLUS DUALOS using Tapatalk
#4 · (Edited)
jt gave you the best recommendaton I believe. P0455 is difficult to handle without a scan tool. Without it, you will have to replace a part at a time. You already replaced gas tank cap, fuel vapor purge valve, and are going to replace canister vent valve. If this doesn't work, then you will have to examine fuel vapor line and the filler hose/tube for a hole.
An alternate path is to pay your mechanic to attach a scan tool to OBD port and activate purge valve/canister vent valve, and go from there.
#9 ·
Honestly, when mine fail, I'll probably just replace them myself as well. They are inexpensive and easy to replace. I'd rather avoid going to a dealer (the whole scheduling thing, missing work, etc). Not to mention this way, I have control over exactly what is done to my car. I've had dealerships screw up just as much stuff as they've fixed (while fixing things). :)
I avoid dealerships at all costs...
#11 ·
*Still having issues*
I have replaced the Purge Valve canister, the Purge Valve solenoid, and the gas cap. The P0455 code seems to come and go now with a "Tighten Gas Cap" readout. I thought I had fixed the problem when the code went away on the first engine start and stayed off for about a week. I'm not really sure what else I can do other than a smoke test to the EVAP system. If anyone has anymore suggestions, I'm open to them. Thank you all!
#13 ·
I agree. Smoke test is next step. You may want to crawl under and visually check hoses/pipes/connectors that fuel vapor touches. I used home made smoker that burns incense. My P0455 was on my other Ford. Sorry I cannot coach you on Impala.
#12 ·
No matter they will be covered on the powertrain warranty till 100k.
Object-ID=3975448 Owner=Patchak, Roxanne
LMD=09-Dec-2014 LMB=Patchak, Roxanne
The emission parts listed here are
covered under the Emission Control
System Warranty. The terms are
explained in the Emission Control
Systems Warranty on page 23
under “Federal Emission Control
System Warranty” and the
“California Emission Control System
Warranty.”
Important: Certain parts may be
covered beyond these warranties if
shown with asterisk(s) as follows:
. (*) 7 years/70,000 miles,
whichever comes first, California
Warranty coverage.
. (**) 8 years/80,000 miles,
whichever comes first, Federal
Warranty coverage. (Also
applies to California certified
light duty and medium duty
vehicles.)
#16 ·
I still haven't done a smoke test yet to my vehicle, but I would like to see if anyone can understand why something happens. So I clear the P0455 code on my vehicle and it stays off for days. The only time the code comes back on is after I remote start the vehicle. The remote start works fine. I drive the car to work and when I come outside to start it up again, the light is back on. Then that leaves the remote start ability to not work until the light is gone. I'd just like to see what others think about this. I believe this is odd because would the light not come on if the system sees there is a problem? Why does it wait until I remote start my vehicle to pop back up?
#17 ·
My po 455 code and others were FINALLY cleared by a visit to a different GM dealer (sharon chevy phoenix NY) dealer (and a few phone calls to GM) who LISTENED TO ME and hooked the car up to the Tech 2 machine !
This cured my codes and THEN my car passed the NY emissions test!
It DID cost me $65 bucks tho even tho I b*tched it SHOULD be covered under the EMISSION warranty as diagnosis work!
The original dealer (Burritt chevy Oswego NY) replaced a load of emission parts (free and under warranty)and wouldn't hook me up to the Tech 2 machine claiming it UN-necessary!
Yet my car STILL wouldn't pass the NY emission test.
After b*tching at GM several times they sent me a $100 service cert. for my hassle.
I posted my journey on this elsewhere in these forums.
Good luck to you................
#19 ·
When all else fails.
Replace the FUEL TANK PRESSURE SENSOR.
I found the Probe end, ... broken right off from ... the module.
The light went OFF and stayed OFF.
