So I have a 2014 Impala 2LT (45,000 miles) that has the Overkill Tune (91/93), Cold Air Intake and 80mm Throttle Body. Everything has been working great for the last 3-4 weeks (Other than slight surging at startup which Will said he can resolve) until the other day when I turned a corner and the "Service Stabilitrak" came up, ABS Light and No Power Steering.
I used the Autocal to see if I can read any codes and none come up. I was able to select "Clear DTC Codes" which I did even if nothing showed up and it resolved the issue TEMPORARILY. I started the car and got about one block away and it happened again.
I have been researching online as to what the problem could be and its driving me nuts. I have read that it can be a wheel speed sensor, a MegaFuse and possibly the throttle position sensor.
Looking to see if anyone has had this issue and what the problem could be. I know I can go to the dealer and have them scan it for $$ but trying to avoid this if possible. I emailed Will to see if he can help and am waiting to hear back from him. I'm thinking it may be the 80mm throttle body?? I may put the stock throttle body on to eliminate the Overkill one.....Thoughts?
1FastImpala
1FastImpala
