2008 Impala Hard starting when cold
14K views 19 replies 4 participants last post by  chaser77
#1 ·
2008 3.9l 6cyl flex fuel. This is my sons car. Starts and runs well when it's warm out. When the weather has turned cold, it starts hard after it sits for 6+ hours. It turns over fine but engine stumbles and he has to press the accelerator to get it to start. Takes a long time to start. Once it starts, you can smell the fuel out of the exhaust, very rich smell. He will go to work for 4 or 5 hours and when he comes out it will start up fine. He says its worse the colder it gets outside, and the longer it sits. Apparently it did this towards the end of last winter and he failed to tell me. But he thought the issue just went away cause all spring/summer/fall it started up just fine. Now it started doing it again this winter. Any ideas?
#3 ·
Im gonna say its perhaps the coolant sensor. Not the temperature sensor for the gauge, but the coolant sensor that sets how much fuel to add or NOT add when it's cold.
Is the money light on ?
Any codes stored ?
#4 ·
check engine light is on, has been on for over a year. took it to a couple different places and they kept telling him his gas cap was loose. We knew it wasn't. I did buy a new gas cap too but the light came back on repeatedly. Don't have a code reader. Need him to take it to auto store to get the code read. He's working long hours right now and hasn't had a chance to do this.
#5 · (Edited)
You may have more than one issue here. If you bought a Dorman gas cap I would not necessarily trust it. New from those guys means Never Ever Works. However. The vent purge valves at the tank are known to cause issues as is the one under the hood. However, neither will cause the issue your having....... I don't think.
Edit
Spelling. Dorman not Dormant
#6 ·
I did change the vent purge valve at the tank last year at recommendation of auto parts store after they read a code. Not sure if my “new gas cap” is a dormant? I ordered a basic code reader that should come tomorrow. Will update when we get a chance to look at it.
#7 ·
Got the code reader. Code is P0172 System to rich bank. Gas cap is not a dorman. The code reader has a "live" mode that reads a lot of other variables, most of which I don't understand. The care seems to run good after it starts. Even idles fine. I did clear the code just to see if it would come back right away and it took about 3 miles of driving and it was back on. found out it also pulls hard to the left. Have to turn the steering wheel quite a bit to the right just to drive straight! because of that the front left tire is worn uneven and very little tread left.
#10 · (Edited)
At -25% fuel trim the computer thinks the engine is running extremely rich. But with the engine is running ok when warm I bet it's not running rich at all. Instead the PCM thinks it is due to it miss calculating the ethanol percentage in the fuel, and this is the one piece of information that the scan tool that your using isn't telling. Unfortunately a lot of non OEM scan tools do not tell you what the PCM thinks the percentage is, you will need a Tech2 or similar scan tool. Check the ethanol percentage and if it's greater than 10% (and it probably will be) you'll need to use the scan tool to reset that percentage. With a Tech2 the reset will be in the engine special functions menu.
Sent from my Pixel 3 XL using Tapatalk
#11 ·
So something must cause this “miscalculation” of alcohol %. If I get it reset with the right scan tool, is it just going to happen again? Would a local auto parts store have the right scanner and be willing to reset it? Heading to autozone later to pick up oil and filter too as it is past due.
#12 ·
It's a software anomaly. It can happen again. In the 7 years and 150k miles of driving that I have owned my '08 Impala this miss calculation has only happened to me once and I do use E85 from time to time with no issues. The auto parts stores won't have a scan tool that is capable of doing a reset, disconnecting the battery won't reset this either. You'll have to take your vehicle to a Technician/mechanic that has a GM Tech2, Snap-on, OTC Genesis or other very expensive scan tool to do the reset.
#19 ·
I think Eric from South Main Auto addressed that in the video. Keith from New Level Auto has done a couple of vids on those recently as well. One an older Cadillac. It's apparently a GM thing especially in the older ones. There is evidently a "reflash" for some of them to solve this. Mine fortunately is a 2006 and did not have the Flex fuel or E85 feature. I don't miss it.
