Stalling/turning off during driving
1 reading
35K views 8 replies 5 participants last post by  GrizChev
#1 ·
Recently my Impala started stalling out on the way to work. At first it was during sharp left turns but now it's also stalling while going straight. I'm just driving and it will shut off without warning. No check engine light and the car will start up just fine after that.
I don't know what's wrong but I have at least two suspects: fuel pump and power steering pump (latter may be debunked by driving straight and stalling)
Also the car makes a whine when turning left, it's not the bearings this time and I filled the pump to the appropriate level.
Please help me diagnose this problem.
#2 ·
Without any CEL/MIL it is hard to say where to look. If you had a Scanner that can test for live data while driving you might be able to tell what is going on at the time the car shuts off. Also most them Scanners would have a Saved data area where it can or you can set up to freeze frame the system when the car dies.
I guess here is something to question. Does your CEL come on when you start the car for testing the light? (May be bad bulb if no light when starting car)
When it shuts off, Does it shot off all power to the car or everything stays on just car shuts down?
What was the TEMP of the car when this happens? Could it maybe reading a OVER heat reading and going into protection?
Does the car once in park or N start back up and drive on again with ease?
James
#6 ·
Power steering pump should not kill the engine.
Could be a fuel issue though, if your car is a model that has a fuel filter that is not in the tank would replace it.
#9 ·
@cfmckeever
Welcome to the forums. You've posted in an old thread as if you were in that old conversation. That's okay except you won't get enough help because no two incidents are alike - or for the same year/model and and upgrades.
Strongly suggest you start a new thread of your own. Indicate model year and model LS LT etc. Write your actual observations.
