For about 6 years, my 2013 Impala Limited LT has had a wheel speed sensor harness problem that causes my Stabilitrac light to come on randomly when I turn left.
It usually does it every morning when I pull out of my driveway. My driveway isn't very steep but I wonder if the weight of my car shifting onto that wheel within 10 seconds of me starting it up is causing it.
It will randomly make a weird noise and activate the warning light at other times when turning left, even on level ground.
I had the left front wheel bearing assembly and sensor replaced in February. The speed sensor harness was replaced in March. Before both of those things happened, my ABS warning light came on and wouldn't go off.
Two weeks ago, the Stabilitrac light started coming on again. Has anyone else had this problem?
