Cons of 22" rims
45K views 26 replies 19 participants last post by  mjv2k1
#1 ·
Anybody have 22" rims on their chev? Was thinking og getting some for my 13' LT.
Heres the thing. I got kids in the back and we get quite a few groceries and other stuff that would go in the trunk. Worried about rubbing back tires on wheel wells.
Can anyone tell me their negative edperiences with 22" rims?
#2 ·
The biggest con I can think of is making your car look as ridiculous as this...
#4 ·
You can't really ask anyone on this forum about rims bigger than 20" or else you'll get those kind of responses all day.
To be real, you'll most likely be fine with the 22's and people in the rear, I see a countless number of impala's around here with 22's, you may have to bang your rear top strut plate up outta the way a little more but other than that you should be fine with 22's.
#5 ·
I do think that twenties fit the car really nicely and fill up the wheel well. You already know the twenty two's will somewhat decrease ride quality and if you're in a snow area, snow traction. I definitely wouldn't go larger than 22 though. I think if you get larger than twenty twos, you're going to be getting real concerned about every pothole. I'm already concerned with twenties........ generally though, I think you'll be fine with 22s and can balance the aesthetic positives to you with the negatives. But in the end you're the one who needs to look at your car.... and every time you look at it, you don't want to think, "I should have gone with 22s". If that's what your heart is set on, go with it.
Reactions: VladThe
#7 ·
Like already mentioned, the biggest "cons" are going to be;
- Harsh ride (compared to 17"/18" wheels)
- You'd have to use extremely low profile tires - and you could easily bend/damage the tire and/or rim if you hit a pothole...
- You'd probably have to do quite a bit of "customization" in order to get them to fit properly (depending on offset, etc).
- Even simple things like large speed bumps could be problematic if the wheels stick out past the fenders - especially if you have weight in the trunk....
Lots and lots of cons, IMO. I'm not a fan of "big" wheels, but even if I were, I'm not so sure I'd put them on these cars - they just aren't designed for such a large wheel like some of the newer cars are.
Just my two cents!
#9 ·
To clarify.....I personally would only go 18 on 8th gens and 20 on 9th gens...like yours........so your 22 on a 9th gen is not that far off from what i would do - if yours was an 8th gen and you were asking about 22s, I would try to dissuade you.
Reactions: plano-doug
#11 ·
There's a huge difference between a donk and a vehicle with a plus sized wheel. Rule one, don't ask people who don't have 22's about 22's. Every word is tainted by assumption and bias and maybe a few other things.
Instagram pages and facebook groups tend to offer fewer of the veiled insults that come when asking about plus sized wheels. Do a search and you'll find pages dedicated to your gen.
#16 ·
Hello,
New to this forum. I just bought a 2018 Impala LTZ Premier. Wanted to go to a 22 inch rim. I have the same color as your vehicle. By the way it looks damn good. I was wondering what size do you have on yours rim and tires? Thanks
#13 ·
I tend to be fairly conservative on things like bigger wheels.
I am a fan of doing things right so I'm not "that guy" causing an accident.
To do it right tends to cost a lot more $$$$ than just the wheels. You're probably looking at $2,000 or probably more in "incidentals"
The wheel bearings, steering joints, brakes, and suspension become a real concern when you go larger than 20 or so on the Epsilon Chassis Gen 9 Impala... The suspension is not just the struts and springs. Trailing and lateral arms need to be beefed up among other things. Even upgrading to stockish 18" wheels can be a challenge on the Gen 7 & 8 W-Chassis and that just requires the 18" compatible rear struts and springs along with the SS/LTZ trailing arms.
Wheel bearings, tie-rod-ends, and ball joints are just something you'll get to keep a close watch on and replace more often than you would with smaller lighter wheels and tires.
You can upgrade the brakes to around 13" and maybe larger for $$$$.
The W Chassis A-Arms, and rear lateral & trailing arms can be beefed up with aftermarket tubular parts. The Epsilon chassis can probably be beefed up in a similar manner. Having done just the tubular rear suspension mods I can tell you it's not cheap. If you want to maintain a safe vehicle, once you move to those wheel sizes, it's not an optional modification.
The lower spring perch on the struts may interfere with some tire/wheel choices. If you modify the stock struts you will adversely affect the ride quality and safe handling. Coil-Overs are an option that will not affect the safety and ride quality but again with the BUCKS $$$$.
Not to mention the fact that the rims and tires are ex$pen$ive $$$$.
Standard Comprehensive Insurance will not cover non-stock size wheels if you hammer them on a pothole, curb, or speed bump. You'll have to add a rider to your policy. $$$$$.
Once you do that they know you have larger wheels.
Insurance companies are run by weasels. They are not working for you even though you are paying them. If you have an accident they may force you to prove that the modified wheels and suspension weren't the causal factor before they cover the liability say nothing of the comp and collision claim to your lienholder.
#15 ·
2014 on 22's
The ride suffered a bit, not as bad as my Chrysler, potholes will ruin your day, also do not put the 44psi-50 that the tired are rated at, stay with the 34 that's recommended, I've had them on a year, love them, no other size to me would look right, and rides well enough for me to justify putting them on
#20 ·
I just bought a 2018 Impala Premier (24K miles) with the original 20" Bridgestone Protenza tires. Horrible road noise. Less noise on blacktop but horrible on lighter and concrete surfaces. All the reviews before purchasing said Impala Premier had a quiet cabin. I read the tire post in the Forum, but most were from 2014-2016. What's current for tires and rims to make that quiet touring ride?
#21 ·
I may be wrong, but I think tread material and pattern have more to do with road noise than tire size. Sites like tirerack rate loudness of tires.
I also wonder if the prior owner or a bad mechanic did some work on the car and did not put some of the sound-proofing material back in place correctly.
#25 ·
I just made my final payment on some 22s. Beforehand, I upgraded the braking system with cross drilled slotted rotors and carbon ceramic brake pads. Saving up right now for a fully loaded strut package (front and back) that has a 3 inch lift with 1 inch spacers to combine. Had 20s before but 22s will be the final size I'm putting on the slap box. Can't forget the hub centric rings. I own a 2003 Impala 3.4L. "The Silver Surfer" 😜
