I have a 2008 Impala LTZ and when I open any front door I hear a clicking noise. Thought it was blend actuator but can't be sure. Any thoughts out there?
RetiredPauly, my 2011 impala is doing exactly that. I don't have any other issue with A/C, dashboard gauges or cabin lights. Will I still need to replace the BCM or is there a separate timer module that I need to look for?Sounds like a relay cycling for whatever reason.
BCM wakes up when you open the door and a bunch of stuff comes to life. Never heard it on my 06 LTZ but would not surprise me.
Try this
Sit in the car after you shut the engine off. Remove the key but do no open the door. Wait a minute or 2 until the interior lights shut off and the radio times out. See if the click you hear is the same as the one you hear when you open the door.
It may be that timer thingy that allows you to hear the last couple minutes of the radio etc after you shut the car off.
Then, when you open the door to get out if it makes the same noise as you heard to begin with.
Maybe.
Clicking behind center console
My 2009 impala just started this problem. I took the trouble shooting tips and these are the results that triggers the clicking:
1). I initially Opened the door after it has been sitting for over 2 minutes. Stops after a minute or so.
2). After the clicking stopped, I turned on the car. Moving either the driver side or passenger side temperature control from cool to heat and back down to cool reproduced the problem. It would last a minute or so and then stop. But if I moved either the driver side or passenger side temperature control toward heat while the clicking was occurring, the clicking would stop immediately. turning the fan or A/C on or off, switching vent positions or switching from outside air or recirc did not reproduce the problem. However, It did come to a point that no matter what changes I made to the A/C settings I could not reproduce the problem.
3). So, I turned the car off and removed the key and waited for the dome lamp to turn off. I opened the driver’s door and got out and waited. After a minute or so the problem would return and last a minute or so.
4). I got back in to the car and restarted the car. I was able to reproduce the problem once again by activating either of the temperature controls as stated in step 2). I did not wait this time to see if the problem became non-reproducible after a period of time, indicating it may be an intermittent problem with the activation of the temperature controls.
5). Once I was able to reproduce the problem the 2nd time, I turned the car off and exited the vehicle. After a couple of minutes after closing the door, the clicking began and once again stopped after a minute or so.
With this additional information, what is your best guess? Also, It seems the noise is coming from behind the center console or slightly left of the center console.
Still good info. Impalas are known for blend door problems. You can buy them on Amazon for around $15. Two are very easy to replace if you have small hands. When door was mentioned I thought he meant he had a clicking when it opened. Typically these make noise when you shut the car off. 3 small bolts, 7/32nds or 7mm, can't remember which and a thumbdrive ratchet will get it done.I realize this is an older thread and probably the trouble was solved but never shared here. I don't know if their experience was like mine. But I'll chime-in with mine. Maybe helpful to someone. It's been a few years. Might get details out of order.
One day, unexpectedly, one actuator on my 2010 started clicking when I opened the driver door. I didn't realize how things work. I felt around on the dash and identified about where the loud clicks were coming from. It stopped.
A few weeks later I went into my garage to get something, and the car was clicking. It hadn't been driven and I didn't have car keys with me, and had not touched the car.
From googling I discovered the various modules wake-up at times. Subsequent to that I started checking on it. Several times overnight it was clicking. Then would stop.
It started affecting battery voltage so I had to get serious. At the time, I wasn't driving it much. I was gone for work every week.
I still don't have clarity on why a module was waking up overnight inside the garage, and why the module was sending a signal to an hvac actuator. But it did. I read somewhere the car tracks ambient inside temperature and opens the recirculation/ fresh air door if it gets too hot inside. But I had no way to verify.
Long story shorter, I fixed one then later another failed. In the end I replaced all four actuators (dual climate control).
Happily I got a heads-up online about pre-setting each actuator so its position matches the removed actuator (jumper wires off car battery to drive new actuator motor until matched). In the end it all came together. No more overnight clicking. No clicking at all now.
