Has anyone ever replaced the alternator on a 2012+ 8th gen? I do have an electronic service manual and here are the basic removal instructions from it - just curious if all of these steps are *really* needed - and had a few questions about some of them:
1. Why would you need to remove the drive belt idler pulley (step #2 ) - can't you just use a long wrench/socket to release the slack of the serpentine belt via the tensioner pulley (instead of removing a whole pulley)??
2. Not sure why you would have to remove the engine mount strut (aka dogbone) - unless it's just physically in the way
Does anyone happen to have a link to a video - I was unable to find one. Generally speaking, seems like a pretty easy alternator to replace since it's right on the front/top of the motor (not buried in the back like some).
Thoughts?
Thank you!!!
Sent from my TbooK 16 Pro(E5C8) using Tapatalk
GENERATOR REPLACEMENT
Removal Procedure
1. Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection.
2. Remove the drive belt idler pulley. Refer to Drive Belt Idler Pulley Replacement .
3. Remove the right engine mount strut. Refer to Engine Mount Strut Replacement - Right Side .
4. Disconnect the engine harness connector (1) and remove the battery positive fastener (2).
5. Remove the battery positive cable (3).
6. Remove the generator fastener (1) and the engine harness (2), from the generator.
7. Remove the generator mounting fastener (1) and remove the generator (2).
Removal Procedure
Thoughts?
Thank you!!!
