2017 Chevrolet Impala 3.6L V6 Battery Voltage Testing and How To Replace The Battery
2.3K views 5 replies 2 participants last post by  29 Chev
#1 ·
This winter has been a cooler than normal winter where I live and about a week ago I noticed when starting up the engine (V6) in my 2017 Impala that it didn’t sound quite normal one morning after sitting for a few days. At this time I also noticed that there was a message on the DIC (Driver Information Center) display about identifying me as Driver Number 1 for a few starts afterwards. The temperature has been below freezing here for the last 60 days – normally we get a January thaw for a week or so but that did not happened this year. A few days ago I got the voltmeter out and checked the battery voltage showing at the positive and negative battery posts (not the terminals) after the vehicle had sat overnight at a temperature of about 10°F (-12°C) – got a reading of 11.9 volts (yellow flag). Started the engine (cranked ok) and then checked the battery voltage after a minute (both displayed on the DIC and the voltmeter) and was getting a reading of 15.1 to 15.3 volts. I have noticed that the battery voltage being displayed on the DIC while driving for the last few months always seemed to be about 15.0 – 15.3 once the engine had been started and running for a few minutes and never seemed to drop much but I do a lot of short trips (about 4 miles) so the under hood temperature never gets very warm this winter. I did a few more voltage drop tests between the battery posts and terminals just to verify there was not a connection problem and they checked out ok. The battery that came with the car when I got it had been replaced back in 2022 about 4 months earlier than when it was traded according to the service records I got with the car but the car had only been driven about 40 miles in that time period so it sat for a lot of days. My experience with batteries has been that being left without the engine being started once or twice a week tends to drain down and recharge a battery can make a battery fail prematurely – especially with newer vehicles that have kept alive modules like a 2017 Impala does. I have a battery that I remove and charge periodically from my summer car over the winter months so it got placed in the trunk as a backup plan (along with the booster cables I keep there) and I ordered a new battery for the car which I picked up yesterday. This morning I decided to do a voltage test using my Fluke multimeter which has the ability to record minimum and maximum voltage levels over time and thought I would share the results as it may help others get a better understanding of how battery voltage can change as a battery ages and what seems to be an acceptable voltage level can drop to a point where modules may not work properly when the load of a starter cranking and engine is placed on them.
This morning I popped the hood and connected the meter before starting the engine and got a reading of 12.01 volts - temperature this morning was just above freezing at 35°F (2°C) – slightly higher than thee voltage level I had gotten when the temperature was at 10°F (-12°C). I then placed the meter in the Min/Max record mode and left it connected and I started the engine and let it run for a few minutes. I got a Maximum voltage reading of 14.96 (vehicle running and charging) and a Minimum voltage reading of 9.34 volts (engine cranking).
This confirmed to me that purchasing and installing a new battery would be a prudent thing to do. Some might argue that since it is the last week of February and I might have gotten another summer and fall out of the old battery and this may be true but here is a few of the reasons I chose to be proactive rather than reactive. The battery is almost 3 years old and the longer it remains in the vehicle the more likely it is that it will fail at some point in the future to start the engine. The alternator is trying to recharge a battery that is close to failing every time that the engine starts and as the condition of the battery gets worse the charging system will have more demand placed on it which can lead to having to replace both the battery and the alternator when the battery gets to the point where it will no longer crank and start the engine – I was taught a long time ago that an alternator in newer vehicle systems is there as a battery maintainer and not a battery charger. Years ago when vehicle charging systems were overbuilt alternators were more forgiving when batteries were no longer performing their job properly and a vehicle would get boosted a few times when the weather got cold for a week or two. In modern vehicles each component of the charging system is not overbuilt due to weight and cost factors and a weak link in the system will quickly cause other components to fail.
After replacing the battery and installing the new battery I used the meter and did a similar test – the new battery had been sitting in the trunk overnight so it was very close to the same temperature as the old battery. I measured the battery voltage of the new battery before connecting it and got a reading of 12.7 volts and once connected I turned the headlights on for a minute and got a reading of 12.3 volts after I turned the lights off and before starting the engine. The Maximum voltage reading I got was 15.3 volts and the Minimum voltage reading I got while cranking was 10.25 volts.
The Maximum voltage readings (14.96 versus 15.3) is only a difference of 0.34 volts but the Minimum readings (10.25 versus 9.34) is a difference of .91 volts which is significant since the Minimum voltage level is what each module has to operate with during the time the engine is cranking over to supply fuel and spark at the proper time to make the engine start and run. At 9.34 volts on a day where the temperature is just above freezing if the weather turned cold and the vehicle sat for a couple of days the Minimum voltage level could drop to below 9 volts and that is when modules can get confused or simply stop working properly.
Stay tuned and as time permits I will post more information about how to replace the battery and some of the fun I had along the way. I encountered a seniors moment and left the new battery in the trunk with the trunk lid closed (since it was drizzling) until I removed the old battery - keyless trunks - what a joy.
Discussion starter · #2 ·
Please Note: All the following information is supplied as is - use at your own risk and expense. It may or may not be the proper way to replace the battery on a 2017 Impala with a V6 engine but it worked for me. Before starting make sure the new battery is not inside the vehicle (like inside the trunk with the trunk lid closed) and is the correct amperage and size with the proper post orientation.
To begin removing the battery in a 2017 Impala the location is under the hood on the left hand side - in the first picture I have already removed the top of the battery cover from the battery box. There is a hold down screw and retainer at the front of the battery box that secures the batteries lower edge so the battery cannot move. This screw requires a 13MM socket and extension to get to and the screw can be unthreaded from the hole in the battery box but the screw and retainer can be leaned towards the front of the battery box at the front and does not have to be removed from the battery box. The negative battery cable terminal nut can be loosened and then the terminal can be removed from the post and set off as shown - it may be necessary to use a small flat screwdriver to spread the terminal apart so it can rotate and slip off the battery post.
There is a plastic fuse assembly with a cover and latch that needs to be opened to allow access to the positive battery terminal - on my vehicle there is a piece that has been broken off the cover - probably from a previous battery replacement before I got the vehicle. Once the latch is released the cover can be folded up and this will allow you access to the positive battery cable and the fuse connection studs and terminals that supply power to various locations on the vehicle.
Use caution when loosening the nuts on the studs for the fuse connections - support the terminals as you try and loosen the nuts on the studs so the fuse legs are not stressed. Someone really cranked on the 250 amp stud nut when they secured it as I had to use a 3/8" drive ratchet (13mm socket) on it but it finally moved. The nuts on the three smaller terminals were designed to be held captive by two slotted ears on the sides of the terminals to catch the washer at the base of the nut but one of the nuts on mine was not - use caution so you do not drop one and lose it. Once the positive battery terminal has been removed from the battery post and the wires at the rear removed the fuse assembly can be unclipped from the sides of the battery box (one clip on each side) and the fuse assembly can be removed and set off to the side. It took me a few minutes to figure out how the fuse assembly was clipped on and there is a slot at the top of each clip that a flat screwdriver can be inserted into and then by pushing the screwdriver handle towards the battery will release the clip - once one clip is undone the other one should just lift off the top of the battery box.
With the fuse assembly removed there is a metal lug with a strap that is over the positive battery post - probably a safety measure - the metal lug can be flipped off the post and folded towards the rear of the battery box. The battery can then be slid forward about 3/8" to release it at the base from the retainer molded into the bottom of the battery box and then the battery can be lifted up and out of the battery box. There was not much room to get my big hands down to get a grip on the battery so I improvised and use a pair of small vise grips clamped to one of the posts to enable me to tilt the battery enough so I could slip my one hand in and under the battery to pick it up and out of the battery box - use this method at your own risk as the battery post could break out of the case and battery acid could then leak and get on your skin resulting in burns. A better method would be to invest (or make) a battery strap out of rubber and slip it over the two terminals to create a handle to lift the battery out of the battery box.
Discussion starter · #3 ·
Once you have the battery removed you can inspect the battery box and remove any debris - if there is any evidence of corrosion you may wish to use a product like Fluid Film to spray the areas to slow down any future corrosion or rust from occurring. It is also a good thing to inspect the battery cable terminals where they contact with the battery post to make sure they are clean and free from tarnish or corrosion. Once things look good and you are satisfied with everything you can open the trunk and grab the new battery - wait a minute - the trunk needs electricity to be opened! It was at this moment I mumbled a few choice words and realized I am getting older - it had been drizzling so I had left the new battery in the trunk and closed the lid to keep any moisture out of the trunk. I had to put the old battery back in the car and then reconnect all the wires and terminals so I could open the trunk. At first I just set the terminals on the studs and installed the nuts in hopes of not having to tighten the connections down securely at the positive end and then I connected the negative cable - Nope! This resulted in various modules being confused - heard the fuel pump run for a few seconds, looked and saw a check engine light on the dash (ignition was off), and of course when I tried to open the trunk nothing happened. Ended up removing the negative cable, securing all the positive connections snugly and then reconnecting the negative cable after about 15 minutes of waiting and I was finally able to open the trunk. At the risk of being repetitive - make sure the new battery is outside the vehicle before you being to remove the old battery! I then had the joy of removing the negative cable and undoing all the positive connections again - I learned my lesson - I hope you don't have to if you change your battery!
As I said if everything looks good and the terminals are all cleaned up you can set the new battery in place - mine came with handles -thank you. Make sure the screw and retainer are still leaning towards the front of the battery box at the top so the battery can be dropped straight down to the bottom without the lower lip catching on the retainers at the front or back. The battery can then be slid towards the rear of the vehicle so the lip at the bottom catches under the rear retainer molded into the battery box and the front screw and retainer can then be installed and snugged up. At this point make sure you install the metal lug on the strap over the positive battery post to secure it in position.
The fuse assembly can then be placed back on top of the battery box, the terminals installed on the studs in their proper locations and the positive battery terminal can then be placed over the positive battery post and a small flat screwdriver used to spread the terminal apart as it is forced down onto the post - a light tapping with a screwdriver handle may help get it down so the top of the post is level with the top of the terminal but be gentle. The nut on the terminal can then be tightened as well as the nuts securing the terminals on the fuse studs - again be gentle as you do not want to stress the ears of the fuses. I am sure there is a torque spec for the nuts on the studs and I strongly urge anyone doing this to find them and use a torque wrench so that things are tight but not stressed by overtightening things.
Once the fuse assembly connections are secured the lid can be folded down and latched and then the negative battery cable terminal can be installed on the negative battery post - caution be prepared to see and hear a spark as you do this - at least I did. The negative terminal may also require the use of a small flat screwdriver to spread the clamp as it is gently tapped in place so the top of the post is flush with the top of the terminal.
You can now apply a coating of your favorite non conducting corrosion preventative on the terminals - I use Fluid Film as it is non conductive and can be easily removed or touched up as required and it also has a capillary property (it creeps and migrates into crevices) from my experience.
The battery box cover can now be installed to make everything look car show correct as shown - there are notches in the front of the cover at each side that slip over the pins molded onto the outsides of the battery box - you may have to spread the inside of the cover a little bit to get it to slide over the outsides edges of the battery box. Once that is done the rear of the battery cover can be spread slightly and slid down over the battery box sides at the rear and the two tabs at the rear of the sides of the cover can be engaged into the slots at the rear sides of the battery box.
It is my hope that this information helps someone else in replacing a battery on a 2017 Impala with the 3.6L V6.
Discussion starter · #5 ·
Thanks for the kind words. Not everyone will have access to a volt meter (or oscilloscope) that can record the lowest voltage reading that occurs while the engine is cranking like I own and I am not advocating that anyone should rush out and buy one as they are not inexpensive. However, if a car battery is only showing a voltage level of 11.90 volts or less after the vehicle has been sitting over night at a temperature of 10°F then it might be time to get the battery tested to see how good or bad it is condition wise. A battery is a lot easier to replace at the owners convenience than when it fails and the owner needs to go somewhere and cannot - most auto parts stores have a meter that can test a battery and often do not charge for the service.
Discussion starter · #6 ·
Just wanted to do a follow up since today was the first day I drove the car - 2 days ago when I put the new battery in it I only started it and moved it back and forth a few feet to make sure it would start and allow me to shift out of park and to observe what appeared to work or did not work after having the battery disconnected.
On that day I observed the following:
The engine started and ran ok and the transmission shifter worked ok and I was able to shift in and out of park
The settings for the power seat, the radio presets and other settings appeared to still be retained and working
The radio was not tuned to a station and had defaulted to the lowest FM frequency - figured this was probably normal
The DIC (Drivers Information Center) display for the tire pressure readings was blank - figured I would wait until I drove it before worrying about it.
This morning when I drove the car for a few miles I observed
The tire pressure numbers on the DIC had repopulated and appeared to be the same as they were before the battery change
The clock was set to the wrong time - I reset it and the date to the correct status.
Other than that everything else appears to work as it did before and today I observed a charging voltage of 14.5 volts to 15.2 volts being displayed on the DIC when I checked a few times during my drive - if I encounter anything else that does not appear to be correct I will try and advise
