11-04-09
"Engine Hot A/C Off", No Engine Light, Temp Guage reads dead Cold. Cooling Fans are running full boar after engine start and car is cold. This happened after I was on my way to work (6 miles on the freeway). All was good, then BAM! the message comes up and guage reads dead cold (and the engine is hot after driving for 10 mins).
I pulled connector off coolant temp sensor and connected to a new one I picked up at Advance Auto ( but not installed in block) just to see if original unit was not reading. Hard to get a volt meter to the pins on the installed sensor to ohm it out. The engine hesitates to start for a brief moment and after start with new sensor connected and "Engine Hot A/C Off" still shows up with guage reading Cold. Not sure if battery has to be disconnected to reset ECU or if not necessary since there is no check engine light.
I connected connector back to sensor in the block and restarted. Engine again hesitates the first time starting briefly and "Engine Hot A/C" comes up again and coolant temp reads Cold. Note: after the 1st start when connecting new sensor and 1st start with original sensor, hesitates briefly to start... any other start after that starts up fine as long as I don't switch sensors (hope that made sense).
I forgot to mention that I did get my oil changed the day before at the dealership and had my tires rotated. They have to perform a transducer cal for each wheel when they are rotated since they the car has the "Tire Pressure Monitor System". I called them to see if this may have been a result of they "calibration" possibly and they replied that the message could be from a multiple of reasons and it would cost me $95 just to take a peak (Diagnostic Fee... that's funny)
Any help is very appreciated
UPDATE! 11-05-09
I was driving home after work yesterday and my check engine light did come on. So when I got home I just disconnected the battery for about 20 seconds and reconnected. Started the engine and the temp gauge went up to proper temp (so it's not the sensor, i assume) and no more ENGINE HOT A/C OFF message.
Then this morning going to work the message came up again about the same point as it did yesterday (axp 6 miles on freeway) morning and check engine light came on in the afternoon on my way home as did yesterday (my trip to work is about 10 miles mostly freeway).
UPDATE! 11-06-09
I reset the battery again this morning before going to work. All was good again and now it's back on... same thing after 6 miles, like clockwork. I will verify tonight if check engine light comes on again. Any tips
UPDATE! 11-05-09
UPDATE! 11-06-09
