08 windows won't roll up
19K views 5 replies 4 participants last post by  tallred
#1 ·
I have an 08 Impala with an issue with the windows. Driver window is halfway down and won't go up. Rear windows seem to be disabled as well. Passenger window does work from local control. I have checked fuses and relay. I don't see any broken or cracked wires. I purchased a new master control switch and it didn't make any difference.
If anyone has any suggestions I would appreciate it. I've searched all over and can't seem to find posts with this same issue. 20 deg temps with an open window makes me want to stay home until I can get this figured out.
#2 ·
Is the passenger window working from the master control?
May be the window regulator. Some of the older gm cars have had issues with the regulator cable snapping. Usually when the regulator is bad with a snapped cable the window will be able to be moved freely by grabbing it and sliding it, but not always the case. Have seen regulator motors go bad as well. Not too bad to replace them if it is the regulator.
If it were mine, I would pull the door panels off, will know real quick if the regulators are bad.
If the regulators are not bad, check voltage at your switches where the windows are not working, can then check voltage at the motors connections when bumping the switches to see if they are getting voltage.
#4 ·
I previously owned a 2008, 2011 and 2012 Impala LTZ. I now own a 2014 Impala 2LTZ.
I did not have window problems on the 2008 model - but did replace the LF and RR door lock actuator assembly. Door panel removal is VERY easy.
Do your rear windows work from the rear local / door panel switch? If so, I suspect you have one or more broken wires in the harness that goes from the LF door, through the rubber conduit accordion near the door hinge area (which would affect operation of the LF door master switch). You can dislodge the conduit as it is a press fit on the door and the A pillar, and carefully use your fingers to see if there is one or more broken wires. If so, you may have to CAREFULLY cut open the rubber conduit to replair the wire(s).
One thing to check - have you inadvertently activated the window lock-out switch on the LF door master switch, which would disable the other three windows? Since the windows stopped working suddenly, I'd bet it has to be an electrical wiring issue - probably a broken wire.
#5 · (Edited)
You can maybe stretch the rubber out of the way and do the repair, but you gotta be good with bungee cords and duct tape :)
Seriously, on the one or two I've had to repair, I was able to do it without cutting, but I mighta needed an extra pair of hands - it's been a while :(
#6 ·
My thought was that my window lock switch went bad. I hoped that getting a new master switch would remedy that. Unfortunately, it did not. I have pulled the rubber boot in the door and inspected the wires. Everything appeared to be sound. (I'm familiar with the broken wire issues as I had to repair the wire for the rear defrost located on the passenger side.
I have checked the other windows at the local switches. The only one that works is the RF- and only from the local switch. That's what lead me to believe it may be an issue with the window lock switch. I'll try pulling the panel tomorrow to see what I can find.
Thanks for your input.
