How to lift the rear suspension for heavy loads - Chevy Impala Forums
Wagon Discussion Discuss all topics related to B-Body station wagons from Chevy, Buick, and even to the Oldsmobile Custom Cruiser.
post #1 of (permalink) Old 06-04-2014 Thread Starter
boxcaprice's Avatar
Hello everybody,
I need your kind help.
I am on a road trip with my '85 Caprice Wagon to South America (anniversary drive for her 30th) and due to the heavy loading the rear is sacking too much to have sufficient ground clearance for bad roads.
So I need to get her lifted and the solution must be able to take some abuse.
I have been contemplating 3 different options and would like to hear from you guys which one works best:
1. Coil spring spacers (if yes which ones and where to get)
2. Harder coil springs (what about just some from the last generation Caprice Wagon from the wrecker? if new ones, which ones and where to get)
3. Different shocks (least favoured by me right now as the ones I have are quite new)
Keep in mind that I am on a low budget, so no fancy & expensive solutions.
Looking forward to everybody's input
boxcaprice is offline
post #2 of (permalink) Old 06-04-2014
Caprice Classic with Class
Old Bones's Avatar
Quoted: 72 Post(s)
I'd look into air-shocks if I were you
Holly 0-83670 4 Barrel Carb. Headman Headers. Magnaflow Cats. Flowmaster Delta 50 Mufflers.
Electric Fan. Compu Star Alarm. Sony F-50 dash-cam with GPS Antenna. Crazy Canuck behind the Wheel.
Old Bones is offline
post #3 of (permalink) Old 06-04-2014
Quoted: 919 Post(s)
Yeah, I remember that my 2000 LeSabre had rear shocks that would automatically adjust the height of the rear end, depending on what was in the trunk. It was pretty cool - every time you started the car, it would adjust them. I guess they did that because the trunk was so damn big on that car (kinda miss that LeSabre - had so a nice ride!) - was a pretty big car!
post #4 of (permalink) Old 06-04-2014
Quoted: 99 Post(s)
Huh, my mom's 01 LeSabre doesn't have that...
I'd recommend the Air Lift 1000. Highly recommended for B-Body wagons. Had them on my 92 Caprice, though they were old and un-connected.
Little over $80 on Amazon
*2001 Impala Ls - 134k
Precision 6262 Turbo, ZZP Z3, CXRacing intercooler, ZZP 3" Cat-back, Muffler delete, Bosch 42.5# Injectors, Bosch fuel pump, CTS-V Brembos, Stainless lines, CM GP springs, Dorman solid sway bar, SPEC-D LED headlights, LED heads and fogs, Quad tails, C5 reverse lights, All LED interior, LED 6 gauge cluster retrofit, LED puddle lights, LED underglow, Debadged, Dipped emblems, Color-matched trim, Kenwood DDX271, Polk Audio dxi6500 components, Polk Audio db690, Hifonics GLX100.4, 2x Polk Audio db1240 in custom box, Hifonics ZRX1800.1D, KMC District, Nitto NT555G2, SS tail covers, SS spoiler, SS Lip, 20% tint, Black mesh grille
*2005 GTO - 72k
LS2/6SPD FOR SALE
*2014 Impala LT Limited - 35k
RYD SLO is offline
post #5 of (permalink) Old 06-04-2014
Quoted: 919 Post(s)
Yeah, they called it "Electronic Level Control". Honestly, not sure if it was an option or standard equipment - sounds like it might have been an option. That car even had automatic windshield wipers - the car would detect rain on the windshield and automatically turn the wipers on! Like I said, I really liked that car - wasn't exactly a great looking car, but was extremely comfortable!
post #6 of (permalink) Old 06-04-2014
Quoted: 99 Post(s)
Yeah, my Mom's car is pretty highly optioned. its the "Limited" which is the top tier. Auto wipers, heated leather, and the like. Only thing I thought it didn't have was the sunroof. Could be that that particular function stopped working before we got it, don't know. But it is a damn comfortable car
*2005 GTO - 72k
LS2/6SPD FOR SALE
RYD SLO is offline
post #7 of (permalink) Old 06-04-2014
Quoted: 82 Post(s)
Airlift bags should be your ONLY consideration here they operate on 5-35psi easily supplied with a bicycle tire pump. They keep the load on the spring seats rather than the shock tower and don't compromise ride as much as other options.
I have had OEM air shocks and then later airlifts on the same car and I would never consider airshocks again. Shocks run MUCH higher pressures harder to fill, place extra load on the shock mounts, more expensive. Some of the b-body guys with cars that came with auto-level shocks modified the system to run the lower pressure for bags. The bags last longer too.
Dwayne J is online now
post #8 of (permalink) Old 06-05-2014 Thread Starter
boxcaprice's Avatar
Thanks for your swift replies guys!
I will try the air lift then. Sounds like an affordable option and your arguments for it make sense.
Will let you know how the installation went and how I feel about the results when I'm done with it.
Cheers.
post #9 of (permalink) Old 06-05-2014
PAK_A_BOWL's Avatar
air shocks are awesome but don't run them on the same line, the shock companies sell line kits, buy an extra one and run them separate or they'll push air back and fowarth. for instance you make a hard left the passenger shock goes down and the air goes to the driver side which emphasizes your body roll
PAK_A_BOWL is offline
post #10 of (permalink) Old 06-05-2014
Quoted: 82 Post(s)
Good point on running separate lines good tip with bags too.
Shocks can work and add capacity so I can see why someone would like them after using them but again if you had experience with the bags in the same application I think you would like bags better.
Helps if you let them get good and warm in the sun to soften up so you can get them into the spring.
Shocks run on high pressure 20-150psi I think is typical, Airlifts are 5-35psi. I learned this the hard way when hauling roofing materials with the airshocks on the wagon and the gas station compressor only went to 90psi which was not nearly enough for the heavily loaded car.
post #11 of (permalink) Old 06-07-2014
62BillT's Avatar
Quoted: 17 Post(s)
Also consider "Load Levelers". The are Heavy Duty Shocks with Springs built into them.
I've had them all actually, Air Shocks, Air Bags, HD Springs, Rubber Blocks, etc, but when the back end of my '71 Impala needed a little lift, I choose the Load Levelers. A quick and in-expensive way to get a little lift and/or to carry a heavier load. I even installed them on my '66 C-10 once. Both times they worked great.
Bill
62BillT is offline
post #12 of (permalink) Old 08-14-2014
HERD546's Avatar
I run the AIR LIFT bag system on my 95 Caprice wagon. I have had air shocks on cars in the past and like the way the air bags work. The other option would be a set of MOOG Cargo Coils they are a variable rate spring. Both about the same money.. The ride quality is better with the bags too.
PAUL R DUMDIE JR.
HERD546 ISSCA 2158
W9DWP AZISSO 460
www.theherd.com
1996 DGGM IMPALA SS
1995 BLACK Carprice SS WAGON SOLD..
1992 Dk Gray Caprice SS WAGON SOLD..
2008 Impala LT
2002 Impala LS
2009 White TAHOE Z56 PPV..
HERD Club Vice President & Events Coordinator.
HERD546 is offline
06 Impala Clunking noise rear suspension dtnel 8th Gen Suspension 1 03-22-2019 05:57 AM
66 Rear Suspension JAImpala66 1st - 5th Gen Suspension 1 12-16-2018 05:50 PM
2pcs 6255 Rear Trunk Lift Supports Struts Shocks With Spoiler For Impala 06-14 RSS Bot Impala Diecast Toys Cars on eBay 0 08-07-2018 07:30 PM
2 Rear Trunk Lift Supports Struts Shocks Gas Springs For 200-05 Chevrolet Impala RSS Bot Impala Diecast Toys Cars on eBay 0 01-25-2018 04:30 PM
2 Rear Suspension Struts Shocks Free Delivery Fit 00-11 Chevrolet Impala RSS Bot Impala Diecast Toys Cars on eBay 0 10-07-2017 07:10 PM
