engine and tranny swap - Chevy Impala Forums
United States Events, meetings, and local discussions.
post #1 of (permalink) Old 01-12-2014 Thread Starter
Bear069's Avatar
I am unsure if anyone has posted a thread about this yet or not but I have a 2004 base model impala with the 3.4l I am wanting to swap it out for the 3.8l with a supercharger I'm unsure if I can do a direct swap or if I need extra things I know I will need a new ecm bcm and new cluster and of course a new center console which means new seats to since I have the 60 40 bench seats I'm just curios to know what else I will need and what I'll need to do I plan on getting a front wheel drive 3.8 so I don't have to convert it to tease wheel drive even though I would live it to be it is just a bunch more work
Bear069 is offline
post #2 of (permalink) Old 01-14-2014
SuperDave's Avatar
Send a message via AIM to SuperDave
Get the motor and trans and try to get the whole harness if possible, then you'll need to get the fuel line adapters and tune the PCM. That should be it, no need to swap the cluster or BSM or even the console. It would be a good idea to swap the fuel pump while your at it, I do believe the L67 pump is a higher flowing pump.
2001 Impala 9c1: SLP CAI: L67 coils:PRJ wires:ZZP volt booster:Fuel pump rewire:Trans cooler:HD diff/axle:Home made Shift kitrilled 180* Tstat:Flipped MM's:GTP dual exhaust:Aero force scan gauge:Whelen 90watt Strobes front/back wig wag reverse lights:Whelen air horn:Wig wag headlights.
SuperDave is offline
post #3 of (permalink) Old 02-07-2016
Misty's Avatar
I have a 2004 Impala that I love but a friend totaled it. It has a 3.4 L in it and I found a 2000 Impala with a blown engine. Can I take the 3.8 L out and put my 3.4 L in.
Misty is offline
62 Biscayne Tranny Swap screech858 1st - 5th Gen Engine Performance 5 04-18-2012 01:54 AM
Tranny Swap Question TuckerN 1st - 5th Gen Drivetrain 7 11-19-2009 12:27 PM
engine tranny swap 40willys 1st - 5th Gen Engine Performance 0 11-13-2009 03:12 PM
tranny swap Jam545 Chevy Impala 7th Gen Discussion 5 03-09-2009 04:24 PM
1958 tranny swap options? hunterbats Automotive Discussion 1 01-02-2009 07:49 PM
