07 Chevy impala ss - Chevy Impala Forums
United States Events, meetings, and local discussions.
post #1 of (permalink) Old 12-26-2017 Thread Starter
domination2580's Avatar
Quoted: 5 Post(s)
07 Chevy impala ss
So I've been having oil consumption and now I have multiple misfires as well as afm or DoD won't activate so stuck in 8 cylinder mode...any experiences or idea?
Sent from my SM-N950U using Tapatalk
domination2580 is offline
post #2 of (permalink) Old 12-26-2017
Yanis07Imp's Avatar
8 cylinder mode
Have you checked for any OBD codes? Many will stop the DoD to function. Also, check the oil pressure switch, if it is faulty, only 8 cylinder mode
Yanis07Imp is offline
post #3 of (permalink) Old 12-26-2017 Thread Starter
Quoted: 5 Post(s)
Yes, p0300. Had mass air flow code, changed that. Cleared them and now just the one p0300
post #4 of (permalink) Old 12-26-2017
Quoted: 210 Post(s)
That is a random misfire code. With burning oil and that code, would suspect head gasket or rings may be the problem. I am however not a mechanic, just do the vast majority of my own repairs. Would lean towards compression check to pinpoint which specific cylinders you are having the issues with.
The Following User Says Thank You to 12 lt For This Useful Post:
domination2580 (12-26-2017)
post #5 of (permalink) Old 12-26-2017 Thread Starter
Quoted: 5 Post(s)
Well the plugs are pretty fouled up. Plan is to change plugs and wires and do compression checks while I'm doing that.
post #6 of (permalink) Old 1 Week Ago Thread Starter
Quoted: 5 Post(s)
Ok so, an update.....once again more misfire codes, I replaced the valve covers, and plugs, still burns oil. Is there a new oil pan gasket? What would cause my oil to be still dropping?
post #7 of (permalink) Old 1 Week Ago
Quoted: 307 Post(s)
The LS4 motors have four cylinders which get shut down by the active fuel management system (AFM). I don't understand all the details, but the bottom sides of those four cylinders get sprayed with oil to keep them lubricated while shut down. Apparently, this oiling can result in some of the rings sticking which results in additional oil consumption.
The new gasket controls/reduces the amount of oil sprayed on the cylinders, to prevent the rings from sticking. But it does not unstick the rings. For that, there is a procedure that dealers can run which involves putting solvent in the cylinders to unstick the rings. I think they pour it down the spark plug holes and let it soak the rings for a while. Once the rings are freed, the oil consumption should go down.
domination2580 (1 Week Ago)
post #8 of (permalink) Old 1 Week Ago Thread Starter
Quoted: 5 Post(s)
I wonder if I absolutely need to do that procedure for cleaning the rings.... or if I can just do the oil pan gasket?
post #9 of (permalink) Old 1 Week Ago Thread Starter
Quoted: 5 Post(s)
And also, would u happen to have that part number for the new oil pan gasket?
post #10 of (permalink) Old 1 Week Ago
Quoted: 307 Post(s)
Like I said, the gasket won't unstick the rings. The oil consumption problem will still be there.
That said, the soaking procedure is easier than the gasket swap. Removing the oil pan is a pain. Removing plugs and pouring solvent isn't very hard. The key to that is knowing all the steps in the procedure. Does the piston need to be at TDC? What kind of solvent? How much? How long to soak? How to drain and re-fill/re-lube the engine to prevent damage? If you can figure out how to do all that, then go for it. For me, it was worth a few hundred dollars to let a pro do it.
post #11 of (permalink) Old 1 Week Ago
Quoted: 307 Post(s)
Here's the GM p/n I found: 12643081 .
There's a bulletin regarding this, 11-06-01-007, but I can't find a pdf of it. It gives more details of the procedure.
If I find any more info, I'll post back later.
post #12 of (permalink) Old 1 Week Ago
Quoted: 307 Post(s)
Re: TSB 11-06-01-007
See post #3 in this thread: https://www.impalaforums.com/chevy-i...ion-08-ss.html
Chevrolet Caprice, Impala, Impala SS, 1991-1996 Reconditioned OEM Chevy RSS Bot Impala Diecast Toys Cars on eBay 0 08-30-2017 04:40 AM
1965 1966 Chevy Impala Original Radio Knobs Caprice SS 65 66 Nice Condition SS RSS Bot Impala Diecast Toys Cars on eBay 0 08-22-2017 08:10 PM
Chevy 1965 Impala SS Rear Trunk Quarter Panel Moulding (Right) RSS Bot Impala Diecast Toys Cars on eBay 0 08-22-2017 04:00 PM
Chevrolet Caprice, Impala, Impala SS, 1991-1996 Reconditioned OEM Chevy RSS Bot Impala Diecast Toys Cars on eBay 0 08-11-2017 12:30 PM
Impala Bobs Custom Aluminum Billet Grille 1962 Chevy Impala SS Bel Air Biscayne RSS Bot Impala Diecast Toys Cars on eBay 0 08-08-2017 11:10 AM
