my 96 posi is worn, thinking about 3.73 or 4.10. will i have to do anything with the stock tranny to make this work? Also does anybody know where in the philly area i can get this done right?
how do you know when your rear end is worn? can a limited slip rear end get worn?
Yes LSD can get worn, happens alot.
Check by putting left foot on brake pedal, right foot on gas pedal. hold for 1-2 seconds...
Park car...
Get out and see if you have 2 tire marks...
If not... Posi/LSD has failed.
Boo that means mine is either on the way out or done.... booooooo ! How much am I looking for a rebuild and a new posi and gears ?
-A
about 74% of the time it will burn both tires but there are some times where it wont.
its going out or is worn ( if ur not the first owner of your caprice or impala u know someone was enjoying the posy and burning out.....)
my friend works at a tire shop and my car is sooooo loud that they love when i come in and do a burnout ( my car has 240000....) the first time i tried it
( on shop cement kinda smooth ) it only burned 1 tire .... but a couple weeks later i came in, put water on both tires ( a little water bottle ) burned out for 5- 6 seconds and went out back , 2 tire marks ...
but like i said if its not hooking up its worn :frown:
