Wipers issue
655 Views 1 Reply 2 Participants Last post by  plano-doug
Any know what could be the issue with my 2001 Impala wipers. The wipers park up while turned on intermittent. When I turn them off, the don’t not park all the way down, and the transmission does not make contact with the metal stub. Thanks in advance for any advice. Here is a video: https://youtu.be/rcx2u_zka5k
I think your problem is that little tab I circled in the pic from your video. It's supposed to catch the bottom side of the rotating section to cause it to "shift" into park.
Try raising it up if possible. It may need to be replaced (if that's possible). But it appears that corrosion has worn it down.
In the 2nd pic, you can see how the tab engages the transmission when it's turning counter-clockwise. That must happen in order for the wipers to park.
HTH.
See less See more
2
Reactions: 1
