Hey James, here's what you will be looking at
The 20's will fit but there will be a little tire scrub/rub on tight turns and moderate bumps. Also the 20's will make your car a little jittery on sterring seeing how the height ratio on the tire is low. One other consideration should be how many people are you carrying, just yourself or 2, 3 or 4? I'd get 18's as you will eliminate the clearance problem. If you go 20's you will need to raise the car about 2 inches
Hope this helps.
Hope this helps.
