Radiator replaced, thermostat replaced, heater core, circulates water, air bled from system, still overheats. Even after I flushed system. Please help if you can.Oh, car has a 4.3L V8.
The right mix of antifreeze?
Have you checked to be sure the AC is clear? That covers a large portion of the radiator does it not? Perhaps it is blocked and not allowing air thru.
Common problem, probably had dexcool (orange antifreeze) in it. The smaller hoses that lead back to the heater core are likely plugged/gummed up. Take your hands and squeez them till they let loose anything blocking them.
Did you happen to change the t-stat?
If you did ... remember that the LT1 is REVERSE FLOW COOLING.
You need to buy the proper t-stat. or you WILL overheat.
I personally use the hypertech 160 degree thermostat anytime I change out a water pump in the LT-1, even without a power programmer it works just fine.
Woops ... I missed that George ... thanks. Just thought it was worth noting. :smile:
Does it overheat in city driving or even when steady speed on the highway ?
hoss21502,
There are many possibilities. You need to answer the above question so that people can better help you.
One other question: Were all these parts replaced as a part of solving the overheating problem or was there another problem first?
RMC
