I am wondering I have a whistling noise some times, when I turn the fan control for the heater down is when I hear it the odd time,when fan is on high I don't hear the noise
You failed to include the make, model and engine of your vehicle - but I’m going to assume it is a an 8th generation Impala.
Follow the instructions in the vehicle owner’s manual to remove and inspect the HVAC cabin air filter (very easy). I suspect you have a clogged HVAC air filter, or there is debris inside the air inlet system.
My error - I though you meant the HVAC was making the whistling sound. You may have a vacuum leak, causing the noise. Is the idle unstable? When you turn the steering wheel, you put a load on the engine - which could cause the noise. Perhaps check all the vacuum hoses? Has there been any work done recently in the engine compartment?
I would still remove the HVAC air filter, inspect it and the air inlet area (around the cowl). Ensure the water deflector (under the plastic air inlet grille is in place (after you remove it to check filter) - and that the cowl weatherstrip is firmly in place. Look down into the air inlet area with a flashlight (under the HVAC air filter, after removal) - and see if there are any obstructions or debris that has lodged in the blower fan CAGE.
Hey fellas,
My friend is working on a project and has an 06 Impala SS LS4. We've been looking online for a few weeks trying to find the measurement of height from ground to the bottom of the cradle at each of the mount points. Attached an example pic to better describe the measurement areas i'm...
So, after much reading and debate, I decided to go LED instead of HID for front lighting. The icing on the cake was seeing a coworker's Toyota pickup with full LED lighting and it looked awesome. I guess it was no coincidence that Superbrightleds was running a 10% discount for this Memorial...
So I bought an 06 SS and reverse is out on it. Assuming the reverse band is broke. So I’m wanting to pick your minds on the route I should go.
used from a salvage yard (difficult to find and not guaranteed to last)
rebuild kit ( could be a big job) definitely leaning towards this but if I do...
No codes. I know the wheel sensors can cause but I think I've done replaced them all not at once of course but recently had done. And 2 years ago I did one or other 2 don't remember. Anyone know what's up?
