I am troubleshooting a no start condition. Pass key circuit giving me the problem . I think it's the theft deterrrent relay as I've had problems with that circuit.
Go to your local auto store(Aoutzone, Advance Auto) and check the back section of the Chiltons manual. Some stores already have an open copy on the shelf.
Ok If The Security Light Is Flashing More Than
Likly It Is Passkey 3 Problem/. Take A Meter Measure Across The Key This Will Be The Value Of The Resistor. Under The Base Of Teh Column Thee Will Be Orange Connector Install Your Meter To This Connector , Install The Key , You Should See The Same Resistance At The Base Of The Connector . If Not Replace The Lock Cylinder . When You Take The Old Cylinder You Will See The Wire Break Due To The On/off Of The Cylinder Action . Very Common Problem .
You can try these links:
http://www.wirediagram.com/buick.htm
http://www.alldatadiy.com/index.html
If you are looking for free info, go to your public library and use All Data on their computer.
Good Luck
