If you run it correctly and use high-quality wheel spacers, it is very safe,When shopping for spacers, make sure they're both hub centric and wheel centric. This will ensure that your wheels are centered properly. Also, consider the quality of the metal used. I've seen cheaper brands have their studs shear. If you're looking for a reputable brand, BONOSS is the way to go. They're very well built and will hold up well. I bought a set used 3 years ago and they're still perfect. Are wheel spacers good or bad for your car-BONOSS?Ok so since my Wide body kit idea was a bit far fetched, I was looking at wheel spacers to give me a bit more width. Is anyone familiar with these things? Any pros or cons before I buy?
