Just signed up today,but 2 get this started off right I have a white 2008 ss pimpal.the whole car is bone stock from the lot.lookin for simple upgrades like plug and play so it doesn't affect warrenty on vechical..
warranties and modifications do not mix.
white pimples are the worst
Welcome aboard! :smile:
Good luck with the upgrades!
Nothing internal just performance chips,cold air intakes,better plugs and wires simplw stuff that can be put on and taken off before I take in 2 get service...
first off, there are no simple "chips". any chip you see is crap. you can get your pcm tuned, if thats the route you would like to take. there is a thread stickied around here somewhere with a sh*tload of sites to get your mods from. look around the site and then come back with your questions. also, check out naioa.com.
Right right oem.maybe platium or irridum plugd(hope I spelled it right) ac delco???as far as performance mods go, you and i will be completely different as you have a 5.3L V8 and i have a 3.4L V6. and for plugs and wires, dont even change them. yours should still be good and when they do go out, get OEM.
for plugs, you want ac delco iridium, but i dont see why you would need them already...
as far as pcms go, just look around the thread i told you about. you can either send yours in to be programmed or you can just buy one from them, then once you install it, you can send yours to them for a core refund. the pcm is reprogrammable, so make sure you dont let a dealer or someone erase it and set it back to stock.
