I have a 1994 Cadillac Fleetwood with the 350 LT-1. For awhile I've known it gets stuck in 3rd and won't shift back down. That doesn't bother me too much. But the past 2 weeks it has been running really bad. At any random point while driving I can step on the throttle and it sputters and bucks with almost no power. Then, the power just kicks back in and the car drives as it normally would. This can happen from a dead stop, at any point while driving, or when I'm just barley on the throttle it starts bucking.
This generation Fleetwood has on board diagnostics. So I got in and checked the troubles codes it is giving.
00-44 ....................... Left oxygen sensor under voltages (closed loop operation)
00-84 ........................................... Transmission 3-2 shift solenoid problem
01-43 ................................. Key resistor circuit open or shorted to battery
01-44 ......................... Steering wheel sensor circuit open or shorted to ground
02-26 .................................. Serial Data Communication error (shorted/open)
04-62 ........................................... RPM Signal Malfunction
04-72 ........................................... Serial data line malfunction
If anyone could has experience with these cars and could tell me what code could be leading to the problem that would be great. The codes I'm most worried about are 44, 84, and 04-62.
If anyone would like me to give more info let me know. I appreciate any and all help
I don't know if your car has an EGR valve.
Last year my 92 Roadmaster started to bog down, even stall sometimes, when I stepped on it. It ended up being the EGR valve. Same thing happened to my Caprice recently.
It ends up that the valve rides up and down on a rod, and in time there's some corrosion on that bar, and then the valve sticks.
You can reach carb cleaner into it after the air cleaner is removed, that can free it up; spray some in there and move the valve up and down with your fingers, that will tell you if it's the EGR.
