Yeah.... that's badass... I want that on my car now lol
While not in Ontario, I do like the plate sitting in that section of the bumper... never thought of that. I wonder if that'd be illegal here in Virginia...Anyone in Ontario who's interested:
If your plates are 5 years or newer and they have any peeling or cracking, you can get them replaced free of charge along with new stickers due to a defect issue they had (something to do with a reflective layer they put on the plates)
I got mine replaced but they weren't that bad. Not compared to alot of plates I see with half the numbers peeled completely off. But brand new free plates & stickers, why not. Also repainted my lower grill as it had a few big rock chips in it
Thank you! If there is no IAC valve, how does it maintain idle with A/C on and such?No, there is no IAC valve on the 3.6l.
Before I disabled DFCO, I had similar issues if I gave it a decent amount of throttle and then let off of the throttle completely right away. Basically, the car goes into DFCO mode in those situations, which cuts off fuel and lets the cars motion turn the motor (sort of like engine braking, which causes the RPMs to jump up). Then as soon as DFCO disables (get below a certain speed or other conditions), the RPM's drop back down to normal. I also had this happen when coasting onto highway off-ramps. Drove me crazy. Never happens now that I've disabled DFCO (with HPTuners).
I believe that it's all computer-controlled (by varying the main throttle plate).... There are tables where you specify idle RPMs (both with and without A/C), idle rolling speeds, etc... I don't think drive-by-wire cars need IAC valves since they can just use the throttle plate to control idle (since its electronic and computer-controlled instead of beng controlled strictly via the gas pedal via linkages).
