Done. Took out any pictures and most of tue descriptive verbs and nouns in the original post."Please, be more vague. Also, don't post a picture of it."
~Thank you.
Management.
didnt take much work.Done. Took out any pictures and most of tue descriptive verbs and nouns in the original post.
"blower motor" as in the fan that kicks out air for the ac and heater?That is the resistor pack, that controls the blower motor speed. They are a common failure, and will cause the blower motor to run 24/7
Copy!Yep. Sounds like the blower motor burned up, or the pack is bad. Pull the blower motor out from the underside of the dash, and put 12 volts to it. Then put the fan on high, and see if you have power at the wires to the blower motor.
