Has anyone done this upgrade? From what I've found so far it should fit- and the lines should clear the radiator tank. There seems to be a 'cut out' on the flexible shroud for where the lines pass through to the front.
Thanks for any guidance!
Discussion Starter #2
It installed without problem- it cleared radiator tank easily. Just make sure to soak radiator fittings with PB Blaster night before. Ended up cutting lower fitting off - it broke loose - but would not turn in the sleeve that is on it.
