Long story short, I've had this vibration at 60mph-ish and its only when accelerating. I just recently had 4 new tires put on and it did not fix the problem. It didn't make it worse either. So after doing a little searching, I came to the conclusion the CV axle was at fault on the drivers side. I've also noticed a grinding noise when turning left and the vibration feels like it's left front. Almost like a brake pad indicator riding the rotor type of sound. Speaking of which, I did just put new rotors / pads / hardware on the front about 3 months ago.
Tonight I get the axle and yank it all apart. The first thing I noticed was how loose the axle nut was. I had soaked it with seafoam deep creep about an hour before trying to loosen it and it more or less just broke free with very very little effort... The lug nuts put up a better fight. So with that, I'm thinking oh maybe it was that causing the issue. I figured I would try to pull the axle anyways to inspect it and... I couldn't get it out. I need a different pry bar because what I have isn't working. I wiggled the joints around and it felt okay so I'm having doubts it's the CV shaft. I put it back together and tightened the nut to 156ft-lbs plus another little oomph with the breaker bar.
It drove fine. No issue and the vibration is about 90% gone. Just feels like normal engine vibration to me. But with that now I'm wondering two things.
Loose axle nut = very little bearing pre-load. This is never good, so I'm wondering if that is making the grinding sound. Although, I never felt any grittiness while spinning it by hand. And it only makes noise turning left.
Second... how does an axle nut just come off that easy? Did the vibration cause the nut to back off?
Thoughts, opinion, what would you all do from here?
EDIT / Update:
So I drove the car all week since I made this post. The vibration hasn't really changed but I noticed today it was more on the passenger side. I yanked the wheel, checked the axle, took the entire brake assembly off and inspected everything... All looks good. But... I do have quite a bit of axle play (at the transmission, not the CV axle) that the drivers side does not have. I can get a video if possible. The seal is still good, no leaks. So I'm thinking the play is normal.
The nut on the passenger side was tight tho. I took the drivers side back apart and inspected again. Nothing out of place, all looks good. Nut tight, bearing feels fine.
I'm thinking it's either a diff bearing, axle on the passenger side or something else?
EDIT / Update:
