Back in Black
Check the button to make sure wires are not off button. If remotes works the trunk lock actuator is getting power so fuse should be good.
Reactions: WallyLO
2nd that
Likely bad switch or connection. Unfortunately it requires taking the lower dash section off in order to inspect. If it's the switch, go to a junkyard.
