I've got a 2001 impala ls with a 3.8 that I bought without a transmission. Can anyone tell me what all other years and possibly makes transmissions will work with this car. Before its said I know the car is a 3.05 gear ratio but gear ratio don't mean anything to me I tune so I can recalibrate the PCM for any size gear just need something other wise that will plug an play with the wiring
Well i replied to your other post but, if you can do the work you can use any year trans as long as you can change out the range selector and harness that behind the side pan. Its really easy, I've done it before when I put a 2003 9c1 trans in my 99 GS.
