1 - 9 of 9 Posts
Yesterday my '08 LTZ "bumped" into gear when upshifting at low speed. It occurred within 10 min. of start up and did not re-occur for the remainder of the day. This also happened approx. 4 months ago in much the same manner.
I plan on having the transmission serviced at the dealership (considering the flush) and I will certainly mention this episode to the service writer and insist that it be documented. I will also inquire about the "shift kit" that some on this forum have referred to. I know the transmission is this cars' weak link and I wonder if mine is in its' death throes. Should I opt for the flush or a simple fluid/filter replacement?
how many miles do you have on it? Have you changed the fluid before? and if you did at what mileage?
If they dealership can't "reproduce" the issue, they'll do nothing about it. They may document it but that really doesn't mean anything. Mine was "documented" about 5 times before it crapped out completely on me and they asked if it was the 1st issue I've had with it.
A transmission tech friend of mine said that a cold transmission can shift hard and it could be no big deal, just change the fluid w/ a good synthetic and the filter and you should be fine as long as its not doing anything out of the norm after warming up.
Trannies don't ever need to be flushed, but you should do a fluid and filter service every 30k miles.
Discussion Starter · #9 ·
I opted for the transmission flush at the dealership and a fluid change using conventional tranny fluid. As this was done more than a month ago I can report smoother shifting from the 4T60E and no "bumping" when cold.
1 - 9 of 9 Posts
