This is my first time posting although I have read alot of great information on here. First, I am no mechanic by no means. I need some help with my Impala.
I have a 2008 Chevy Impala SS 5.3L V8 engine. I bought the car used and know it wasn't well taken care of.
Anyway, these are my issues.
1)I have a coolant leak. When it was pressure tested, there was steam coming out where the water pump is. I haven't had the water pump replaced yet, but have a new water pump, thermostat, and temperature sensor to see if it helps. I had a message which sense went away, Engine Hot/AC Off with the code PO128 hence the thermostat and temperature sensor.
Sometimes I have no heat and other times I got more than enough.
2) Broken Sway Bar which to my understanding is a common problem with this car. I had it welded as a temporary fix when I had a new cat put in because the PO420 code kept coming off and on. Last night, I got the code again so not sure what is going on there.
3) Tranny Problem Possible. Sometimes it will slip or shift hard. The tranny fluid smells burnt. The throttle body was cleaned and tightened up like it should have been in the beginning. It has helped the transmission some and has stopped the hard shift and slip to where it doesn't do it as often.
4) Service Traction Control, Brake Assist, and Stabitrak message with yellow ABS light with the
Code C0040-0F and Code C0040-00.
I have no idea what is causing this other than what I have already read on here. Wheel Speed Sensor which means new hub, broken wire, bad connection, etc. It seems like the wheel is locking up to keep the car from moving when at a dead stop. Then I might move about 2 inches and the car does it again. Then I could be driving then my Impala acts like there is nothing wrong at all, but I know better. It also feels like something is getting in a bind and won't let the wheel move. It sometimes makes a noise, but it isn't metal to metal This morning on my way home from work, it was a metal to metal sound. Sometimes the sound does not throw the messages. Other times it will. For this problem, not sure where to begin to make it right or if this is part of a bad transmission.
5) Oil Leak Possible. My oil is going somewhere or the motor is using it. Not sure which one it is.
6) AC and Heat Issue. The passenger side works just fine, but the driver's side sometimes works and other times it does not. For the time being, this is the least of my worries.
Any help would be greatly appreciated. If I posted in the wrong place, I apologise in advance as it is my first time posting.
