Car threw up a TPS sensor code so i replaced it cause it would stall at very low speeds if i slightly hit the gas but it didnt fix the problem, was told my PCM would need to be reprogrammed so i bought the ZZP 1.0, was planning on buying it anyways, but that didnt fix the problem either did i install the tps wrong or can it be something else? Its a 04 3800 Series 2 (check engine is on btw)
Discussion Starter #2
Btw the car doesnt go anywhere if i gas it, like if i was trynna catch up to speed to get on the freeway or to pass someone up
