2002 Impala 3.4L V6 LT FWD 242k miles
Was wondering if 17's off a Chrysler would fit my 2006 Chevy Impala?
You're asking a WAY too vague question. You need to do some research. Start with your vehicle.
1.) How many lugs/studs (4, 5, etc.) ?
2.) What's the distance between the lugs/studs?
3.) Do you know what the offset is? Read this:
Now do the same thing for the wheels you want to put on your Impala.
There can be several outcomes, right?
1.) Wrong number of studs = they won't bolt up at all!
2.) Right number of studs, but wrong distance between the studs = they won't bolt up.
3.) Right number of studs, right distance between the studs, but the offset is wrong = causes tires to strike suspension components, or they won't even clear your brake calipers!
And yeah, there are "spacers" to "fix" some of these incompatibilities, but personally ... I wouldn't do that.
Good luck!
Reactions: sheila
