Throttle body spacer?
4K views 8 replies 5 participants last post by  pimpstrocity
#1 ·
I was wondering do throttle body spacer give you any horsepower gains our are they a waste of money? Thanks for any input
#2 ·
IMO waste of $, unless you are going to use it to spray the car.
Try to find a HVIII, real gains of about 20hp. some good starting mods would be:
-FWI/CAI
-HVIII
-L26 UIM & LIM w/ "green gaskets"
-powerlog
-Downpipe
-180* t-stat
if you want to go further than that grab some 1.9 Roller Rockers or a cam
dont forget a pcm tune too!
#4 ·
High Velocity Intake Insert
HVII -orig, HVIII - Improved
The High Velocity Upper Intake Manifold Insert replaces the factory plastic runners in the upper intake manifold found in FWD Series II 3800's. Simply remove the upper intake (leaving the throttle body attached), pull out the stock runners, set the HV insert in the intake and bolt it back down
More torque - The HP gains of the old HV2 were quite amazing. The only issue was a loss in low end power. This meant that only highly modified setups could take full advantage of the high rpm gains. The new HV3 has slighty longer runners to give more HP and torque in all usable rpms!
Easier install - The new HV3 doesn't require special length bolts, RTV or any modifying of your factory setup. It sits entirely inside of the factory upper intake. It can be installed in less than 30 minutes.
More reliable - The HV3 does not require RTV, cannot be seen by anyone looking at your external engine, and it comes with a new intake gasket. Installing the new HV3 actually improves the reliablity of your car by replacing a potentially worn out gasket. Because it sits entirely inside the intake, there are zero sealing issues.
does not work w/ the L26 UIM/LIM, so it's an either/or issue
