I have an '09 Impala LS, and after a repair at a body shop the third brake light is always on at a very low level. It still works, it illuminates fully when the brakes are pressed, but even when the car is completely off it remains on very dim. Worse still, the body shop refused to fix the issue unless I can "prove" they caused it (load of BS). I have it disconnected for the time being to prevent battery drain. I assume it's some issue with a computer somewhere because it's a very strange fault. Regardless, any suggestions for fixing it? Maybe I can run a separate relay off of the brake switch? Thanks in advance for your help.
