Sorry it sounds like a Issue with a Stepper Motor, Not a bad fuse or broken wire. Sadly they do go bad from time to time and one can do it them selves or have someone do it. Even may be cheaper to buy a used cluster. However you can buy new motors online for cheap. Some places will even sale a kit that offers the motor, leds, soldering iron and all that would be needed to do a new setup for I think under 30. Some offer a Desoldering pump and some LEDs or just normal bulbs there are many options out there and no one is really the right one. Just have to look around for one that is best for you.
If you don't have a Soldering pen, or De-Solder pump I would go that way to get the best for your buck. If you haven't soldered before I would do some testing on other things before you work on you Cluster. Also some people offer the tool to take off the needles, if you get one without this tool a Fork works just use some cloth for keeping scratches down...
James
