Here u go
1996 Chevrolet Impala Performance
- 5,733 cc 5.7 liters 8 V 90° front longitudinal engine with 101.5 mm bore, 88.4 mm stroke, 10 compression ratio, cast iron block, cast iron head, overhead valve and two valves per cylinder
- Unleaded fuel
- Fuel economy EPA highway (l/100km): 9.4
- Multi-point injection fuel system
- Main 87 liter fuel tank
- Power: 194 kW , 260 HP @ 4,800 rpm; 330 ft lb @ 3,200 rpm
1996 Chevrolet Impala Handling
- ABS
- 3.08:1 axle ratio
- Four disc brakes including four ventilated discs
- Immobilizer with anti-start code
- Rear viscous limited slip differential
- Spacesaver steel rim internal spare wheel
- Wishbone front suspension with stabilizer bar independent with coil springs , beam rear suspension with stabilizer bar rigid with coil springs
1996 Chevrolet Impala Exterior
- Body color medium body side molding
- Front and rear body color impact absorbing bumpers with rubbing strip and colored insert
- Chrome/bright trim around side windows
- Coefficient of drag: 0.32
- Driver and passenger power heated body color door mirrors
- External dimensions: overall length (mm): 5,438, overall width (mm): 1,969, overall height (mm): 1,389, ground clearance (mm): 157, wheelbase (mm): 2,944, front track (mm): 1,570, rear track (mm): 1,582 and curb to curb turning circle (mm): 11,491
- Mechanical foldable mirrors
- Conventional lens halogen bulb single headlights
- Gloss paint , black paint , metallic paint
- Fixed rear window
- Trunk/hatch body color lip spoiler
- Tinted glass
- Weights: gross vehicle weight rating (kg) 2,424, curb weight (kg) 1,831, gross trailer weight braked (kg) 907, gross trailer weight unbraked (kg) 454 and max trailer noseweight (kg) 109
- Two-speed windshield wipers with W/S wiper mist setting and variable intermittent wipe
1996 Chevrolet Impala Interior
- CFC free liquid air conditioning
- Power antenna
- Front illuminated ashtray , rear ashtray
- Stereo Delco audio system with AM/FM
- Automatic drive indicator on dashboard
- Cargo area light
- Cargo capacity: rear seat up; to lower window (liters): 578, rear seat down; to lower window (liters): 0, rear seat down (liters): 0, all seats in place (liters): 578 and all seats removed (liters): 0
- Front seats cigar lighter
- Digital clock
- Floor full console with covered storage box
- Delayed/fade courtesy lights with four switches in footwell
- Steering wheel mounted cruise control
- Front seats cup holders
- Door pockets/bins for driver seat, passenger seat and rear seats
- Floor covering: carpet in passenger compartment and carpet in load area
- Carpet floor mats
- Driver and passenger front airbag
- Bucket seat
- 3-point reel front seat belts on driver seat and passenger seat
- Front seat center armrest with integral box
- Lockable illuminated glove compartment with lid
- Height adjustable head restraints on front seats , head restraints on rear seats
- Illuminated entry system on interior
- Internal dimensions: front headroom (mm): 996, rear headroom (mm): 963, front hip room (mm): 1,448, rear hip room (mm): 1,445, front leg room (mm): 1,072, rear leg room (mm): 1,003, front shoulder room (mm): 1,610, rear shoulder room (mm): 1,610 and interior volume (liters): 3,231
- Low washer fluid level warning
- Remote power locks with internal switch
- Power steering
- Front and rear power windows with door mounted switches
- Front reading lights
- 3-point reel rear seat belts on driver side , 3-point reel rear seat belts on passenger side , lap static rear seat belts on center side
- Folding rear seat center armrest
- Bench fixed three rear seats
- Automatic operation rear view mirror
- Electric remote trunk/hatch release
- Front seat back storage
- Leather seat upholstery with additional vinyl
- Seating: five seats
- Four speakers
- Leather covered steering wheel
- Passenger illuminated vanity mirror
- Ventilation system with four fan speeds
