1 - 15 of 15 Posts
Part-Time Canadian
I was wondering if you can get the lenses seperated from the backing on the 2003 Impala tail lights. I tried baking it in an oven at work i had it up to 250 F and i couldnt get them apart. Is there something I'm doing wrong?
10-4 you cannot easily seperate. It must be done with a dremel or similar. What are you intentions? This will help us give advise.
lsx impala tail light cover Will make it look better assuming he wants to use all 6 lights basically he could cut holes for two on the trunk and the other on the left/right side
Some items in photo not to scale
also you can not cover the reflectors on the side
still going to require fab work and a donor trunk(so you can take the reflector space from the other trunk)
^^ That's ugly as sh. Must be led bulbs as they are not very bright at all
I think the intentions are cool.. They really need to come out with a bigbody impala tre light set-up again,
I think if you did it like a '62 Bel Air (as opposed to a '62 Impala) then you could get it to look good. You just put the second light where the reverse is so it doesn't look mis-spaced, and leave off the inside light.
Part-Time Canadian
Discussion Starter · #15 ·
its not going to look quite that gaudy i have the inside 2 spaced pretty well i think. and i wasnt going to cover the side reflectors where exactly should i cut with the dremel?
1 - 15 of 15 Posts
