1 - 20 of 27 Posts
I have an 03 impala and when i swapped out the axle shafts I noticed that the ends on my sway bar were broke. If I'm going to replace it I want to upgrade. Here comes my question should I get the GMPD ugrade kit or is there a better kit I also saw doorman and the like for sway bars but I'm not sure but i think the handling upgrade kit from gm would be best. What is your alls opinion
Back in Black
Try to get a solid bar instead of hollow like factory bars. You will see a hugh difference. I think the front is 32 or 33mm. Check doorman, zzp,addco, GMPP and others compare and make your choice
Back in Black
don't remember I thought it was hallow, but I have this setup on my 2002 Buick Regal and it works very good, came that way from factory, has over 300,000 mile on it no problem and I like to attack turns so it has not been babied. Usually the GMPP kit is hard to beat for price, a lot of guys on RegalGS.org got this kit over others.
Call and ask them if it is hollow or not.
Is the gmpp kit better than the gmpd kit?
Back in Black
sorry gmpd is correct
So this gmpp sway bar kit is the same thing as the link I posted for the gmpd sway bar kit earlier just different website and price?
GM Performance Sway Bar Kits
Back in Black
Yep
The GMPP sway bar is solid. I believe it's 34mm. I have it on my 2000 Regal. It's a tough unit and for the price you can't really beat it.
The stock older Wbody sway bar is really a POS. I snapped the one in my Regal clean in half. The GMPP will be a real nice upgrade for you.
Discussion Starter · #10 ·
So are you saying that the gmpp kit on w body store is better than the gmpd kit on gmpartsdirect?
Honestly I'm not even sure what the 'GMPD' kit is. If it's a factory replacement with the same hollow sway bar...then it probably sucks. If it's a solid piece like the GMPP bar that I have, it's probably great.
I can absolutely vouch for the kid Wbody store sells (which is why I posted). I have no idea about the other one in question.
Discussion Starter · #12 ·
This is the gmpd I think it's the same kit as the wbodystore I just can't tell.
GM Parts Direct: pk12456148 - Grand Prix, Monte Carlo and Impala Handling Upgrade Kit
The ends of the bar itself, or the sway bar end links?
Discussion Starter · #14 ·
The ends of the actually sway bar itself separated I guess it's a common thing on the stock bar
Dang, I heard that
Back in Black
metal fatigue on oem crap hallow bars, a lot of them break just back of the eyelet on the bar.
Discussion Starter · #17 ·
Yupp that's exactly where mine broke
Discussion Starter · #19 ·
same here on a 2000 Impala LS. Way to go General Motors:clap: These cars will never reach the rust belt with a hollow sway bar:gaah:
Yeah there's a few things you can count on here in Michigan a lot of salt on the roads and never ending construction
The GMPP bar is hallow, get the Dorman sway bar. Its a totally solid bar and is the same diameter as the GMPP bar, maybe 1 mm smaller but who cares. :eek:k3:
1 - 20 of 27 Posts
