L67 Heads
L67 idler pulleys,
L67 idler stand off,
L67 throttle body,
L67 injectors,
custom PCM,
GTP balancer,
L67 MAP sensor,
L67 heads,
L67 fuel rail,
2 head gaskets,
head studs,
MAP adaptor harness,
bypass valve wiring,
vacuum lines,
brake booster line,
supercharger gasket,
throttle body gasket,
lower intake gasket,
lower intake Orings,
supercharger belt,
GTP valve covers,
GTP valve cover gaskets,
coil pack bracket for 99+ cars,
M90 from an L67,
lower intake from an L67,
M90 bolts,
and new rocker bolts
Theres a bunch of mods you can do after that, the top swap will run you about $500-1000 (even with the free blower). You will want to make sure it is a Series II or Series III blower, not a Series I! (1998+)
