Has anyone found the best route to run the power wire through the firewall to the back? I've been looking and I cant find anything about what to do or the best way to hook into the factory wiring. I have 3/0 wire and plan to install 4 12 subs. Thanks everyone!
2014 2lt non limited
If u look between the center console just to the right of the gas pedal you’ll have to pull back the carpet to see it. Against the firewall. There’s a huge rubber grommet right in the middle u can fit 3 1/0 awg wires thru.
Amplifier is in the trunk. By tail light. All speakers in the car rout to there. If u are just looking to add 12” speakers. Simply tap into the wires on the 6x9 in the rear deck
Do you have a pic showing the location and also what did you use for the positive connection the oem cable one doesn’t work well with the knukoncepts battery terminal
