1 - 8 of 8 Posts
OK, 2012 LTZ, 75k miles, good maintenance, no oil consumption
About a week ago i was sitting in a parking lot waiting on my son, all of a sudden the temp gauge spikes, I get the a/c off, idle engine notification, I mess with the vent to defrost to feet, it drops in a few seconds. I smelled some coolant but no internal drips, no external drips on the pavement. it has happened off and on over the last week, typically in slow traffic or stopped, mess with the HVAC controls, kinda like old school cars with heater core issues, and it drops back in seconds to normal. today it happened at speed and my check engine light is on. and is staying on.
I used to be able to do some work on my rides but this newer stuff relies on top many computer interconnects!
ANY IDEAS? my first thought is a stuck thermostat.
:WTF:
Thanks in advance.
Could be a thermostat, could be a fan issue, could be a lot of things really. I would probably start by getting the codes read and see what they tell you - otherwise, we're all just guessing.
Update. Check engine light was off this am. Cruised as well as she did new. Until 12 miles from home. Went all spastic! Realized I had bought the extra 125k, 5yr warranty. I usually get screwed on those but...water pump, outlet pipe and a bunch of other stuff. On the test drive, the tech dug deeper and found hub assemblies, front struts, and steering gears, power steering pump need to be replaced. The service advisor found out that GM still had warranty on the water pump/temp stuff.
Long story short - my local CarMax service advisor is awesome. The local chevy dealer is awesome, getting a loaner while they work on the Impy.
Sent from my VK810 4G using Tapatalk
1 - 8 of 8 Posts
