Spec D projector headlight blowing fuse
2121 Views 4 Replies 3 Participants Last post by  afarleigh14
Anyone know what might be causing my new headlights to keep blowing my fuse out. My original headlights work fine. Once I got the projector lights they worked for about 2 days then next thing I know the projector part was out but the headlight still worked I just couldn’t see the white line, it also makes my tail light go out in the back on the same side but my brake light still work, it’s just since it’s connected to the same fuse “DRL” it goes out with it until the fuse is replaced. Once I replace the fuse it would just instantly blow it out. I was thinking maybe it’s just the spec d headlight but I got 3 different one and the same thing happens I have a impala limited ltz 2014
See less See more
2
I have the same thing happening. Any fixes?
Return to stock lamps and capsule.
Reactions: 1
Did you contact the manufacturer of the aftermarket items?
I figured my problem. I had some fuses blown.
Reactions: 1
