Gets pretty cold up here and we use our heaters a lot and I noticed last winter that the heater was boiling my right foot and my left foot was freezing.
I had a look and there are two triangular outlets on the air box that just blow straight at the gas pedal so I took an old pool hose and inserted it into one of the triangles and ran it across under the dash to blow half of the heat onto my left foot. (I caped off the end with duct tape and cut two holes that blow downward toward the floor).
The pictures show 1-the hose, 2-the standard outlet, 3-the hose in the outlet & 4-the installed pipe.
This doesn't interfere with your feet and when sitting in the car you don't even see it. It works perfectly now, both feet are the same temp, so if your left foot is always cold try this simple free mod.
