Hello,
Was wondering if I could tap the group expertise.
Trying to replace the rear wheel hub on our '01 LS. I have the four hubs bolts removed but the hub will not budge. Does the backing plate and e-brake assembly come off, too, or just the hub assembly by itself?
I search the forum, found great info on the front hub, but little one the rear hub.
I supposed the hub could be seized in but it's pretty clean back there.
Any ideas would be greatly appreciated.
Thank you much
Remove the ABS electrical connector from the wheel speed sensor (1), if equipped. Remove the park brake cable from the park brake actuator. Refer to Parking Brake Rear Cable Replacement in Park Brake.Remove the mounting bolts from the rear bearing/hub.
Click to Enlarge
Remove the wheel bearing/hub and park brake assembly from the knuckle. Remove the park brake actuator from the rear wheel bearing/hub. Refer to Parking Brake Actuator Replacement in Park Brake.
Installation Procedure
  1. Click to Enlarge
    Install the park brake actuator to the rear wheel bearing/hub. Refer to Parking Brake Actuator Replacement in Park Brake. Install the wheel bearing/hub and park brake assembly to the knuckle. Caution! Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
    Install the wheel bearing/hub-to-knuckle bolts. Tighten
    Tighten the bolts to 75 N·m (55 lb ft).
    Install the park brake cable to the park brake actuator. Refer to Parking Brake Rear Cable Replacement in Park Brake.
    Click to Enlarge
    Install the ABS electrical connector to the wheel speed sensor (1), if equipped. Install the brake rotor. Refer to Rear Brake Rotor Replacement in Disc Brakes. Install the tires and wheels. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
  2. Lower the vehicle.
Thank you very much for the response. I'm bummed I can't see the pictures.
I may have to google how to remove the hub and park brake assembly from the knuckle. I cannot see how they are attached to the knuckle. It's totally kicking my butt.
Thanks again for the help. If anyone has any advice on removing the hub and brake from the hub, that would be awesome.
there is a clip that attches the cable to the brake that comes off . not 100% sure how it's held in there.
You could soak it with pb blaster and tap with a hammer or use a old rim bolted on and wack the rim with a sledge hammer .
