I cant find ANY info, videos, how tos ANYWHERE on how to replace the rear caliper on a 2011 impala. The main problem is i need to put slack in the e brake cable to unhook it from the caliper, but i have no idea how to loosen it up
I believe the adjuster is in the middle of the car, inline with the rear wheels. I seem to recall there being a threaded rod with some nuts on it or something like that (sorry was a few years ago I was adjusting mine). If you follow the brake line, you should find an adjuster eventually.
So I went looking under the car yesterday and your right. Its right behind the "Y" pipe. You can see it running around the flooring right before the heat shield
