Hey all,
can i pound out the wheel studs on my 02 LS without damaging the bearing ?
Also, anyone know if i can get them out without removing the hub ?
Thanks for your thoughts.
Never tried it, but I wouldn't without removing the hub. I would take it out, brace around the stud, heat up around it, and pound it out.
Discussion Starter · #3 · (Edited)
Well....they don't come out unless you remove the hub, but it's not necessary to remove the axle nut. Tap the studs back, unbolt hub, remove old, install new. I fought with pulling the new ones in, they don't go easy. The easiest way I found , since I don't have an air gun, was to start them with the old lug nuts put on backwards, then put the wheel on and use a bar or long torque wrench to pull them in. I was afraid of screwing up the rim, but I didn't.
It may not be right, by at least I didn't break anything...:yikes:
Btw, the hubs are both new. The studs came out easy. A certain
Trans shop over tightened them. Comment witheld...
