I have a 2000, and I can't tell if my rear seats fold down. I've read on here that I can pull the seat bottom out and then remove the seat back, but how can I tell if I can fold it? I don't see any tab, so I'm pretty sure it doesn't. But I want to check before I go removing things from the car.
Thanks in advance :beer:
Will have polyester pull tabs on the back rest near the gaps. If no gaps and no pull tabs then, no folding down. Bottom cushion is removed by pulling up hard. There is a clip on each side about 6 inches from each side. Pull up near this section. Usually the fold down seats have a 60/40 section.
Most likely if you can't tell then, it doesn't have them. Usually very easy to spot
base model does not have them unless it came with a upgraded interior.
