I switched out my 72 impala rear end with the rear from a 96 impala ss. The original rear had drum brakes and the ss has disc brakes, 373 gears and the posi traction. Everything bolted right up with no problem. I noticed that the Emergency brake cables on the 96 ss were way longer than the ones on the original rear and it also has a different fitting on the end that connects to the inner side of the caliper, the fitting is connected to a hook that locks the brakes when you step on the pedal. I have no I sea how to make this work the original cables on the 72 rear end are 37.062 inches and the one on the 96 ss rear end are almost or about 73 inches! Does anyone have an answer so I can get this tool in care of ASAP!???? Here’s a pic of the fitting that is on the newer cable that’s not on the old one
